Navigation Monitor Blank...please help!
Old Oct 8, 2008 | 10:02 PM
allstarmac08's Avatar
3rd Gear
Default Navigation Monitor Blank...please help!
Hey guys, i have a 1997 range rover 4.6 hse...i have a navigation system in there but i have no image on the screen...it use to talk to me and stuff..but no picture on the monitor...you think the monitor is the fault? and now the navigation cd unit in the back wont accept the cd...it will just spit it right back out...please help thanks alot!!!!!
Old Oct 8, 2008 | 10:54 PM
tacomatech's Avatar
Default RE: Navigation Monitor Blank...please help!
I have seen that issue before(blank screen), but there is not a whole lot of information available on these systems to aid in diagnosis.
Also, all of the components of that system are very expensive. In all honesty, you would be better off having an aftermarket navigation system installed. Some of the other people might have more knowledge on this issue than I do, so if you are dead set on the stock system, then you might wait for more to respond.
Old Oct 9, 2008 | 03:12 PM
3rd Gear
yeah i dont know whats wrong...its not that im dead set on having the stock system its just annoying that idk what the problem is...and if its a minor problem then MAYBE i can fix it...but thanks alot for the help! ive been lookin on ebay at just the nav. monitors for sale and the run for about 600 dollars..and thats way to much...maybe a loose wire or something?!
and another question can a bmw smaller nav screen work with my range rover nav screen?
Old Oct 9, 2008 | 09:48 PM
tacomatech's Avatar
I don't know about the BMW nav screen, I doubt it would. You could check your wiring connections, but you probably won't find anything. I would, however, check your disc unit to see if any water has gotten to it, or in the connector, you might find something.
Old Oct 10, 2008 | 02:03 PM
3rd Gear
okay man thanks alot
gilakinlr4
LR4
May 2, 2020 07:18 PM
RobS
Sep 22, 2014 06:34 PM
red rockett
Apr 10, 2008 10:24 PM
red rockett
Mar 6, 2008 02:53 AM
thebearmonster
Feb 13, 2006 10:50 PM
