newbie 94 lwb passenger side fuse
Old Oct 30, 2007 | 01:00 AM
eddy91604's Avatar
4th Gear
Default newbie 94 lwb passenger side fuse
Hi and thanks before hand for all your help. I just got a 94 Range Rover and there are several minor flaws to it. Some I can hope to fix others probably not. One that's bugging me is that the heated seats don't work and the cigarette lighter doesn't either. I searched the manual and these 2 share the same fuse. I looked for the fuse box underneath the passanger seat and I can't find it. I moved the seat all the way forward and I found 2 other fuses butaccording tothe manual, there should also bearound 6 fuses grouped together, which is where that fuse is.
Are these hidden somewhere? They are definetely not in plain view sight. Maybe some one moved it in my car. I looked around but didn't want to poke around too much and maybe screw something up. If you guys have a picture of where that is it would be perfect.
Thanks a lot!
Old Oct 30, 2007 | 02:05 PM
Default RE: newbie 94 lwb passenger side fuse
Look in the fuse block, usually located under or near the steering column.
Old Oct 30, 2007 | 07:34 PM
eddy91604's Avatar
4th Gear
thanks , I already found it by the time I got your message. thanks for the help anyways!
cosmiccharlie
Aug 12, 2020 01:42 PM
Dave Bristow
Feb 14, 2015 01:28 AM
Young
Jul 22, 2009 07:51 PM
Luv2Run
Aug 16, 2005 01:38 PM
