Oil Filters for the RR 02 p38
Old Mar 22, 2011 | 01:14 PM
RROJ's Avatar
Default Oil Filters for the RR 02 p38
Guys which oil filters are best? Atlantic British has a small selection. Most say "short" filters. I'll buy a case of which ever you guys recommend.
Old Mar 22, 2011 | 06:33 PM
LRScott's Avatar
I use a napa gold filter. Seems to work fine. I might try a different one just for heck of it though... Since using it my rover has developed a subtle moan. My other car didn't like it either. The moan could be unrelated to the filter, but we'll see when I change it out. I've heard frams are pretty good. Personally, I will just go with an OEM one from the dealership. My other cars seem to like it more when they get a filter that was actually designed for them.
Old Mar 22, 2011 | 08:47 PM
RROJ's Avatar
Atlantic British has the following:
"genuine equipment" @$12
Brand "Mahle" @ $6
Brand "K&N" @ $14
Brand "Mahle (short) 6 filters for $32
Has anyone out there on the forum have any opinion on any of the non original equipment oil filters?
I'm assuming OEM and "genuine equipment" means the same thing right???
Old Mar 22, 2011 | 09:38 PM
antichrist's Avatar
I've been using Wix and Hastings/Baldwin filters for about over 35 years. They are both well regarded makes.
For V8's I use the long ones, I can only assume there's enough clearance on the RR.
Wix - Long 51512
Wix - Short 51068
Baldwin - Long B2
I pay about $5 each locally for the 51515.
The filter the Rover V8's use wasn't designed for them. They are one of the most common and widely used filters.
Old Mar 22, 2011 | 09:47 PM
gsd2004's Avatar
To be honest I just use whatever the shop puts in. Its last oil change just happened at the dealer so I am back to OEM parts. But I have not noticed any change from what my local shop uses. I just use synthetic oil thats my big concern.
Old Mar 22, 2011 | 09:49 PM
gsd2004's Avatar
Any of you guys replaced your pollen filters recently? I just got mine from Atlantic British, when I took out the old ones I have a feeling they were original! They were awful!
Old Mar 23, 2011 | 01:24 AM
RROJ's Avatar
Thanks for the suggestions. Anyone else out there have any different experiences good or bad? Thanks in advance.
Old Mar 23, 2011 | 04:48 AM
Now that is one of the dumbest things you can do. The only thing a oil shop will install are junk filter costing them a $1.50 and selling it to you for the big bucks.
Only use a Top of the line filter, my choice is either a Mobil 1-301 or a K&N 3001.
Old Mar 23, 2011 | 07:52 AM
antichrist's Avatar
I'm sure the dealer, where he said he had it changed, uses the OEM Cooper filters.
But I agree they likely charge big bucks for it.
Old Mar 23, 2011 | 10:36 PM
gsd2004's Avatar
It works for me, my 98 Disco with 200,000 miles did not seem to mind when I sold it. I think alot of the money you pay for a K&N filter is in the name. But that being said, is it really worth my time and money to go buy a oil filter to give them? I already change my oil every 6 months or 5,000 miles with synthetic. I don't think I will be to concerned right now as the dealer just did the oil change. But if you guys think it is worth the money I would probably rather use an OEM filter I can get them cheaper.
