online rr repair manual
Old Nov 23, 2010 | 08:49 PM
roversprings's Avatar
Default online rr repair manual
I just traded my '02 Disco for an '00 Range Rover 4.6 (couldn't afford both and like the looks of the RR better. Anyways, it has 130,000 miles on it and I plan to eventually do all of the items on DiscoMikes Major Service list, should take some time as the whole process will have a steep learning curve for me I'm sure. Is there a manual I can download for free like the Rave manual for the Disco? I did download the manual that is titled V8 overhaul for my engine but it does not help with fluid changes. Is there a manual or even a book that might be helpful or should I just take one task at a time and seek all the help I might need here on the forum? Just as an example the process of flushing the transmission fluid and then refilling when there is no dipstick to check afterwards seems scary. Having second thoughts about trading in the Disco but too late now. Any help is appreciated.
Old Nov 24, 2010 | 12:34 AM
LRScott's Avatar
rave also has one for RR. You can get it at greenoval.com There are many similarities between discos and rovers so the learning curve shouldn't be that steep . I thought the disco II didn't have a dipstick for the transmission either (The GEMS Discos and Rangies have dipsticks, BOSCH doesn't). Basically, you drain it through the drain plug and then fill it through the fill plug. Once its overflowing, its full. Sort of like changing the fluid on your differential.
Old Nov 24, 2010 | 08:07 AM
antichrist's Avatar
Download the Rave_02 iso from greenoval.
Old Nov 24, 2010 | 10:37 AM
My RR does have a Bosch.
Thanks for the feedback on the transmission, I also saw that you fill till it starts coming back out. If I were interested in flushing the system does some of the atf leave the transmission for a cooling process and if I simply drain and refill won't I be leaving some old to blend with the new? Does gravity bring all of the old out and if that is the case then would I fill, run it for a bit and then top off again?
As for the manual, again much thanks but I can't seem to figure out the greenoval site, could someone attach a link here please if it's not too difficult?
Old Nov 24, 2010 | 01:58 PM
antichrist's Avatar
google "green oval + rave"
Old Dec 3, 2010 | 10:46 AM
luvmyrover1074's Avatar
5th Gear
I can't seem to find the green oval site either, non of the links I have found on forums work??
Old Dec 3, 2010 | 08:36 PM
I searched and searched for the Range Rover rave manual and tried everything until I was finally able to download it on my computer but have to use free software called Daemon Tools Lite to open it, the software works by making your computer think its a disc in the DVD drive. A while back when I got the manual for the Disco it was so easy. Respond if you need further help and I will try and figure out what I did and try to provide the steps.
Old Dec 7, 2010 | 10:23 AM
Chris X's Avatar
You'll have a little fluid left in the cooler that doesn't flow down. There will be some old fluid in some other nooks and crannies including the torque converter.
You could drain the fluid via the drain, then top it back off, disconnect the fluid return line from the cooler, start it up and apply the e-brake and cycle through the gears and leave it in Drive. Have a suitable capture pan ready and watch the coolant come out of the line, when the color of the fluid indicates the new stuff, then you got most of it out. Obviously connecting some additional tubing to the return line would be beneficial so you can watch it at a safe location, not under the vehicle. Another person sitting at the wheel would be a good idea too.
I'm not 100% sure you need to be in Drive to do it with the Rangie, but that's how it works on my Jeep.
Or just figure that 3/4 of the fluid being new is good enough if the old stuff isn't all burned up.
Old Dec 7, 2010 | 11:39 AM
antichrist's Avatar
Here you go:
http://www.lrrforums.com/showthread....890#post164890
Old Dec 8, 2010 | 09:53 AM
5th Gear
Thanks a bunch I really appreciate it!!
dbrockman2
Oct 11, 2013 05:30 AM
flakman
Nov 28, 2006 06:11 PM
dickensheets
Oct 21, 2006 07:56 PM
deluxe21
Jun 28, 2006 12:51 AM
Evian
May 17, 2006 08:31 AM
