Optima Batteries - What size?
Old Nov 2, 2010 | 08:35 PM
krazzz's Avatar
Default Optima Batteries - What size?
Who runs Optima batteries in your Rovers? Their website says that it takes a size 25 but is seems so small. Does anybody run the yellow top? If so, what size?
Old Nov 2, 2010 | 09:34 PM
handsome rob's Avatar
I have a red top in my Disco. It is a beast. I would love to go with the yellow especially when I get a winch. If I remember right they are all the same size; they are just separated by the color tops. I know that my red top is smaller in size than the factory one but has greater cranking power.
Old Nov 2, 2010 | 09:59 PM
krazzz's Avatar
Is yours a 720 CC? Size 25? I've always felt my Rover cranked over too slow. I was thinking about going with the 900 CC.
Old Nov 2, 2010 | 10:51 PM
I do not know which one it is, I bought it about 4 or 5 years ago and it still runs great. I will check in the morning for you if that is okay?
Old Nov 3, 2010 | 06:39 AM
Rovin4life's Avatar
stick with manufacturers rating and above. otherwise the battery goes bad at random times cause all the juice is sucked out to start it.
On a cold day you might be lucky to start.
Old Nov 3, 2010 | 10:06 AM
antichrist's Avatar
The Sears DieHard Platinum are much better batteries than Optima.
Old Nov 3, 2010 | 11:20 AM
hilltoppersx's Avatar
I'm with Tom I run a Sears DH Plat and its fantasmical! with a great warranty 2 boot.
Old Nov 3, 2010 | 11:48 AM
krazzz's Avatar
What size Diehards are you running? I looked on Sears website and they say they don't have any compatible ones. Looks like a size 34 because that is what their gold level comes back as. I wonder why they say the Platinum isn't compatible?
Old Nov 3, 2010 | 12:54 PM
yes i run a 34. there is plenty more room in the box though when i get a bumper and winch i will probably run a bigger battery or cut the jack location wall out and run dual 34's.
Old Nov 3, 2010 | 01:29 PM
antichrist's Avatar
You can't always go with the sizing chart. You have to go with actual dimensions and see for yourself if it fits. Here's the Platinum group 34:
http://www.sears.com/shc/s/p_10153_1...3&blockType=L3
I have this in my D1's, only the P4 (P1 doesn't have side terminals).
