P38 leaking clear oil from under dash?
Old Nov 8, 2016 | 10:53 AM
RROJ's Avatar
Default P38 leaking clear oil from under dash?
Hi Guys,
The Rover has been worry free for thousands of miles until i notice oil dripping slowly on the passenger floormat. I looked up and it wasn't coming from under the dash but where the console meets the dash.
Any clue to what that problem maybe from. The substance is clear but slick when you rub it between your fingers. Any help as always much appreciated.
Old Nov 9, 2016 | 09:26 AM
OverRover's Avatar
" Any clue to what that problem maybe from. The substance is clear but slick when you rub it between your fingers "
Not much up there but the heater core (heater matrix), I would suspect it's a coolant leak. Either the core itself, or one of the o rings.
Old Nov 10, 2016 | 09:51 PM
RROJ's Avatar
Yes, in taking the panel off it was clear that the heater core unit needs replacing. I got 117k out of it. Good right?
rezzrover
May 7, 2013 06:02 PM
Lincoln Tarantino
Mar 1, 2012 09:23 AM
Lincoln Tarantino
Jan 20, 2012 05:55 PM
maxferran
May 13, 2007 08:30 PM
