P38 no low range
Old Feb 23, 2013 | 12:04 AM
ChipG's Avatar
Default P38 no low range
Got my '01 P38 stuck so I had to suffer the indignity of being hauled out of a hole by an Isuzu Trooper today, and afterwards I couldn't select low range. It worked fine before and while I was stuck, but I tried it after being towed out the shifter won't move to the low side of the shift gate. Does anyone have any ideas on what might be going on so I'll have direction to start looking tomorrow? Thanks
Old Feb 23, 2013 | 12:13 AM
Fivespddisco's Avatar
Just to double check
The shifter would not move? That sounds odd.
Old Feb 23, 2013 | 12:18 AM
ChipG's Avatar
It will shift through high range just fine, but I can't get it to shift over to the low range side of the shifter gate
Old Feb 23, 2013 | 12:39 AM
ChipG's Avatar
After some google searching I think something may have broken in my shifter. I did try to rock it out a few times so maybe shifting back and forth broke something. In the post I found the guy removed the shift cover and gate and his shifted into low. Guess I'll start there tomorrow
Old Feb 23, 2013 | 05:41 AM
threalassmikeg's Avatar
probably have some loose change floating around in the h-gate or gearshift mechanism. only a few screws to remove to find out
Old Feb 23, 2013 | 10:13 AM
kfx4001442's Avatar
I have some trouble getting mine ('99 p38) to shift over to the Low side sometimes. I usually try backing up a few feet or pulling forward a few feet. I don't know if it's just in a bind or what, but I have always been able to get it over there with just a little patience and extra effort. Works for me.
Old Mar 6, 2013 | 06:38 PM
ChipG's Avatar
Turned out to be a broken shift ****. Replaced it and all is well
mwyoung
Nov 2, 2011 12:28 PM
Skimino Farms
Jul 30, 2011 07:47 AM
wilson96rr
Jan 3, 2009 10:44 AM
ek5usmc
Nov 4, 2008 02:01 PM
Classic89
Aug 10, 2007 08:58 PM
