P38 w/Ignition Key In warning
Old Jun 24, 2010 | 10:47 PM
workinghard1713's Avatar
Default P38 w/Ignition Key In warning
I keep getting the ignition key in warning while my key has been removed. The ignition is turned off. Has any one experienced this problem and what was the remendy?
Old Jun 24, 2010 | 11:31 PM
LRScott's Avatar
Does your remote entry work anymore?
Old Jun 25, 2010 | 05:31 AM
The keyless entry is deactivated because of the warning.
Old Jun 25, 2010 | 12:37 PM
LRScott's Avatar
Your key might have gone out of synchronization. Your RR is most likely warning you that if you don't re-sync your key fob. Its going to immobilize itself until you punch in the EKA access code. Which is a PIA...
Old Jun 25, 2010 | 03:04 PM
krazzz's Avatar
I think it is just the the little sensor in the switch that tells you if the key is in the ignition or not. Mine used to do it all the time. I sprayed a little dry graphite lubricant on my key and worked it in and out a bunch of times and it took care of the problem. It's really not a problem other than being annoying. It isn't an sign of impending doom or anything.
Old Jun 28, 2010 | 04:45 PM
Thanks Krazzz! I think that was the problem because the last couple of times that I have driven the vehicle when took the key out of the ignition it seems to be fine now. I'll put alittle graphite on the key tomorrow morning.
cipher982
Nov 9, 2019 11:22 AM
will rocket
Off Topic
Sep 12, 2013 06:23 AM
cwmoongrove
Apr 25, 2013 04:54 PM
georgep
Nov 1, 2012 04:30 PM
1998DiscoverySE
Jun 27, 2012 01:56 PM
