P38 windshield washer problems
Old Jun 13, 2013 | 12:28 PM
15degreeGTI's Avatar
4wd High
Default P38 windshield washer problems
When I push the front windshield wash button, the motor is audible but no fluid sprays out. I've topped off the reservoir, no luck. I've also used a small sewing needle to clean out any potential blockage in the nozzles, but still no luck (worked like a charm on my BMW). Is there anything else I need to know or should try? It is a 97 4.0SE
Old Jun 18, 2013 | 12:49 PM
Ringo's Avatar
I have a similar problem, the fluid dribbles instead of squirts. I bought a new washer pump online. Should take all of 15 minutes to replace it. Before I install it, when I disconnect the washer jet line from the pump I am going to put some aquarium hose I have laying around on it and confirm its a bad pump or clogged hose. I've seen replacement jets available as well and I've seen one person fix his problem by replacing his. But I put my money on a worn out pump.
hilltoppersx
Sep 22, 2010 07:44 PM
krazzz
Jan 15, 2010 07:17 AM
rgreenwell8962
Jul 2, 2007 10:09 AM
dailyuser
Jul 27, 2005 09:32 PM
Benhamtroll
Jun 21, 2005 09:41 PM
