Problem with Heater Inlet Pipe Leaking 2000 RR 4.6 HSE
Old Mar 29, 2011 | 05:50 PM
ccasseljr's Avatar
Default Problem with Heater Inlet Pipe Leaking 2000 RR 4.6 HSE
I have the previously discussed problem with leaking of the Heater Inlet Pipe (the O-ring). It's the pipe in the top right side of the manifold that has a little tab held in place by a bolt that screws into the manifold casting. My problem is that the hole in the casting is stripped and the bolt will not hold the inlet pipe in place. Had anyone had this problem and same up with a solution?
928paul
Dec 12, 2011 07:26 PM
ljdiscovery
Feb 17, 2011 07:41 AM
roverdude09
Oct 11, 2009 11:36 PM
vjm530
Dec 19, 2007 11:36 AM
matthiasm
May 7, 2007 04:43 PM
