"Quick" Alternator Question "97 HSE 4.6
Old Sep 28, 2010 | 02:39 AM
6RedRover9's Avatar
Default "Quick" Alternator Question "97 HSE 4.6
I have 1997 LR Range Rover HSE 4.6 ...with the 100 amp Magneti Marelli alternator. Can Anyone tell me if this alternator has a seperate voltage regulator that i can replace Without having to replace enire alternator unit. I am also considering replacing entire alternator with the 120 amp Marelli unit BUT i still have same question concerning the voltage regulator. Anyone know for sure?? Tips,Advise.etc. .....is Truly appreciated!!!!! THANKS in advance......
Old Sep 28, 2010 | 05:45 AM
wilson96rr's Avatar
On mine (96 4.0) the regulator is built into the alternator and it is replaced as a unit.
Old Sep 28, 2010 | 11:53 AM
handsome rob's Avatar
Most modern cars have the regulator built in, so you will need to replace the whole thing. Sorry for the bad news. You can always go to a electric motor shop and see if they will rebuild it with the amps you want, I have always wanted to do that but did not want to wait.
humroot
Feb 26, 2015 11:21 AM
icyhot201
Aug 16, 2010 07:24 PM
mgabriel
Dec 11, 2008 11:53 PM
endneu913
Nov 3, 2007 03:46 PM
Brad S1
May 9, 2007 10:18 AM
