RADIO CODE????
RE: RADIO CODE????
You will have to go to the dealer and have them look up the code. Alternatively, you could drop your glovebox down and check for the presence of a sticker with a barcode on it. If you find it there, then the last 4 digits should be your radio code, unless the radio has been replaced before, then it might not be correct. Another thought it to look on the bottom of the rubber mat on top of the dash, as alot of us Rover techs will write the code on the bottom in case it needs to be entered again.
moocowman
08-31-2011 04:07 AM
bcolins
07-05-2011 08:30 AM
southfloridadiscoII
06-28-2009 11:03 PM
