RADIO CODE????
Old Nov 13, 2008 | 09:36 PM
flyplanes5's Avatar
4wd High
Default RADIO CODE????
How do I get the code for the radio in my 98' 4.6?? I had to remove a fuse and now the radio needs to be reset.
Thanks,
Old Nov 13, 2008 | 10:31 PM
tacomatech's Avatar
Default RE: RADIO CODE????
You will have to go to the dealer and have them look up the code. Alternatively, you could drop your glovebox down and check for the presence of a sticker with a barcode on it. If you find it there, then the last 4 digits should be your radio code, unless the radio has been replaced before, then it might not be correct. Another thought it to look on the bottom of the rubber mat on top of the dash, as alot of us Rover techs will write the code on the bottom in case it needs to be entered again.
dogstarsix75
Apr 24, 2020 01:33 PM
sayeedA
Nov 15, 2011 11:02 PM
moocowman
Aug 31, 2011 04:07 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
