Range rover 4.4 shuddering
Hi guys im new to this site so hopefully this comes out ok ,I recently bought my first range rover [4.4 vogue se 2003 lpg converted ] and found that as im driving when I approach 25-30 mph the vehicle begins to shudder ! but if I continue accelerating and pass this speed the vibrations stop, ive had a quick look at the propshaft on inspection the u joints look ok relatively new. Is it possible the shaft has been taken out and put back in the wrong place and is now unbalanced ? or do I need a new shaft ? hopefully its not a gearbox fault , also if I drive in manual the shuddering does not happen ! any help would be much appreciated I look forward to hearing ideas.
Whenever the truck is moving and at certain RPMs/loads. Info is probably in Rave but I don't know the specs for the 4.4 off hand and really doesn't matter since slippage and other parameters can't be seen/altered without the necessary computers.
To the OP: check/replace the fluid/filter
grantj727
02-12-2011 02:12 PM
TheRedRockDisco
05-05-2010 06:27 PM
