Range rover 4.4 shuddering
Old Jan 28, 2014 | 02:52 AM
jdog30014467's Avatar
3rd Gear
Default Range rover 4.4 shuddering
Hi guys im new to this site so hopefully this comes out ok ,I recently bought my first range rover [4.4 vogue se 2003 lpg converted ] and found that as im driving when I approach 25-30 mph the vehicle begins to shudder ! but if I continue accelerating and pass this speed the vibrations stop, ive had a quick look at the propshaft on inspection the u joints look ok relatively new. Is it possible the shaft has been taken out and put back in the wrong place and is now unbalanced ? or do I need a new shaft ? hopefully its not a gearbox fault , also if I drive in manual the shuddering does not happen ! any help would be much appreciated I look forward to hearing ideas.
Old Feb 9, 2014 | 09:28 AM
tony1963's Avatar
Bad motor mounts.
Old Feb 9, 2014 | 11:54 AM
willrok13's Avatar
Or could be a torque converter/fluid issue. Has the fluid/filter been checked/replaced? What part of the world are you in?
Old Feb 9, 2014 | 01:41 PM
tony1963's Avatar
Yes, it could be the torque converter, too. Doesn't that normally show up when you engage in direct drive or "lock up"?
Old Feb 9, 2014 | 02:31 PM
willrok13's Avatar
Whenever the truck is moving and at certain RPMs/loads. Info is probably in Rave but I don't know the specs for the 4.4 off hand and really doesn't matter since slippage and other parameters can't be seen/altered without the necessary computers.
To the OP: check/replace the fluid/filter
cornerz
Aug 27, 2011 08:42 AM
grantj727
Feb 12, 2011 02:12 PM
clemson rover
May 21, 2010 11:31 AM
TheRedRockDisco
May 5, 2010 06:27 PM
bangkuaidiscovery04
Jul 17, 2009 08:50 AM
