Range Rover P38 Suspension fault will not show on Text book HELP!!
Hi All
Wondered if any one has experienced this problem :I have a 98 Range Rover 4.6 HSE, i recently had a fault with the front height sensors which have now been replaced. But now since having these done my car sits up higher on front than rear. I took the car to two authorised Land rover dealers who have tried to calibrate but to no avail. The problem i am having is there is no fault showing on text book, so dealer says unable to find problem, sensors are new and correct. All settings on suspension work fine, just does not sit level. The dealer said they where able to calibrate but then once road tested calibration settings seemed to be lost. Also car does seem generally higher all round.
Help !!! Pump is new and also pressure switch.... Has any one ever had this problem
Cheers
Jon
![Frown](https://landroverforums.com/forum/images/smilies/udbMv2o.png)
kbarker27
10-13-2023 04:03 PM
Arth111
02-26-2022 06:28 AM
artcareer
08-30-2006 07:36 PM
