Range Rover P38 Suspension fault will not show on Text book HELP!!
Old Dec 1, 2007 | 05:13 PM
jh61's Avatar
3rd Gear
Default Range Rover P38 Suspension fault will not show on Text book HELP!!
Hi All
Wondered if any one has experienced this problem :I have a 98 Range Rover 4.6 HSE, i recently had a fault with the front height sensors which have now been replaced. But now since having these done my car sits up higher on front than rear. I took the car to two authorised Land rover dealers who have tried to calibrate but to no avail. The problem i am having is there is no fault showing on text book, so dealer says unable to find problem, sensors are new and correct. All settings on suspension work fine, just does not sit level. The dealer said they where able to calibrate but then once road tested calibration settings seemed to be lost. Also car does seem generally higher all round.
Help !!! Pump is new and also pressure switch.... Has any one ever had this problem
Cheers
Jon
Old Dec 2, 2007 | 08:36 AM
Default RE: Range Rover P38 Suspension fault will not show on Text book HELP!!
Wish I could help you and would like to hear what the out come is on getting this fixed.
Old Dec 2, 2007 | 04:04 PM
Savannah's Avatar
Hi Jon.
Testbook will never solve the problem.Find someone that has Rovacom diagnostics.Rovacom is far more advanced in setting the airsuspension on the P38.
Regards
Marius.
Old Dec 2, 2007 | 04:21 PM
jh61's Avatar
3rd Gear
Cheers guys
thanks for your help
jon
binvanna
Oct 4, 2013 10:23 AM
aguison
Sep 17, 2012 03:07 AM
artcareer
Aug 30, 2006 07:36 PM
