Range rover P38 weird Oil leak problem
Old Apr 19, 2008 | 12:11 PM
WolfPack's Avatar
Default RE: Range rover P38 weird Oil leak problem
I'm fairly positive the rear main seal is a rather major repair..Probably requires the engine to be pulled/tranny dropped to get at the seal....I would imagine it's a case of not too expensive of a part, but the labor to get it kills ya...
Feel free to correct me...I had the rear main seal leaking on my old '87 pontiac, and this is what I recall from looking into that repair!
Old Apr 19, 2008 | 04:42 PM
pat3d's Avatar
Hi,
Someone on another forum, told me to checkmy crankcase vent to make sure it isn't clogged or blocked because if it is, it can cause the engine to push oil out the rear main seal.
He had this problem once.
Is it the same thing than the crankcase breather filter http://www.classicsagogo.co.uk/acata...le_guides.html
As I'm not a mechanic at all, is it easy to clean it andfirst ofall where is it located(some details would be greatly appreciated)?
Thanks again for your help.
Pat3d
Old Apr 19, 2008 | 05:15 PM
$1200.
You need to go dergrease your engine top and bottom then power scrub it. When done, crawl under it a couple of times a day and see where the fresh oil is coming from.
Is it dripping on the ground, if so where?
Old Apr 19, 2008 | 05:17 PM
ORIGINAL: WolfPack
Wow...oil on the bumper but no spot...that's impressive
Mike are you thinking the IMG was poorly done (if the shop did it) and that's the loss of oil? Are you thinking it's coming out the exhaust and getting on bumper/tailgate that way?
I am thinking it is leaking in a bad way and probably wasn't really replaced.
Old Apr 21, 2008 | 09:24 AM
pat3d's Avatar
Hi,
If this is the intake manifold gasket, should I have oil leak on the floor, or is it only when I'm driving ?
Thanks,
Pat3d
Old Apr 25, 2008 | 01:32 PM
pat3d's Avatar
Hello,
2 days ago, I called the mechanic who changed my intake and head gaskets, and he told me that I had a remaining leak form the rear main seal to take care of.
I'm gonna go for that and make it repair. I hope it will fixmy big leakproblem.
He told me also that he has cleaned the crankcase breather filter, and he didn't notice any problem with the valves stem seals either.
Thanks,
Pat3d
schwuller
Feb 9, 2013 09:18 PM
nicklaeena
Jan 30, 2013 11:58 AM
nicklaeena
Jan 25, 2013 01:32 PM
Lincoln Tarantino
Nov 14, 2011 10:41 PM
