Rear wiper change?
Old Nov 23, 2012 | 04:02 PM
Bishop's Avatar
Default Rear wiper change?
I've had my 1998 RR for years and now I need to change the wiper blades.
The two in the front were simple, the rear blade is a pain.
Do I have to turn on the rear window blade and kill the battery when it reaches the down stroke to be able to replace the blade?
Thanks
Old Nov 23, 2012 | 05:01 PM
95_rover's Avatar
I ended up take the arm off, slide the plastic cap straight off, I think the arm nuts is a 13 or 14mm. It's pretty easy to due and was less time then trying to blade off.
Old Nov 23, 2012 | 08:43 PM
Fivespddisco's Avatar
Turn it on walk around to the back and wait for the wiper to become centered in the window. At that time hit the button to open the hatch. The wiper will stop.
Old Nov 27, 2012 | 02:56 PM
Bishop's Avatar
Thanks you so much, it worked perfectly and too me less than two minutes to change the rear blade.
How did you learn this trick?
THanks,
Rod
Old Nov 27, 2012 | 07:54 PM
THanks,
Rod
Ancient Chinese secret
bcolins
Feb 2, 2014 09:40 PM
bcolins
Jun 22, 2013 08:55 PM
collin Barrows
Aug 28, 2011 07:13 AM
wilson96rr
Aug 12, 2009 11:00 AM
KBW
Mar 6, 2009 07:40 PM
