Rover Sport Supercharged
Old Sep 1, 2014 | 08:52 AM
DiscoJag's Avatar
Talking Rover Sport Supercharged
Hi guys ! I just came over from the Disco side. I traded my 96 Discovery for a 2006 Range Rover Sport Supercharged. I got a pretty good deal, but the PO obviously didn't take much care of the truck at all. Anyway, first question, I got two sets of keys but only one works. They are the switch blade type key. The one that doesn't work will fit in the ignition and the lights come on, but no crank. I've looked around some, and some people say there is a battery, some say the car charges it, but one thing is for sure, it doesn't look like the case comes open easily (fob). I have an owner's manual on order, I didn't get one with the truck. More to come. TIA. Cheers.
Old Sep 7, 2014 | 07:04 PM
LR Techniker's Avatar
The battery in the Key has NOTHING to do with starting the car. The security in this car uses a passive transponder in the key. You can take the battery out and a good key will still start the vehicle. The battery is for the keyless entry.
If it turns in the ignition, that just means the blade is correctly cut for the vehicle. The fact that it won't start, means one of three things:
1) defective key
2) un-programmed new factory key
3) eBay POS "virgin" key.
Scenarios 1 & 3 require a new key. Scenario 2 can be corrected with diagnostic tool.
Old Sep 8, 2014 | 09:53 AM
DiscoJag's Avatar
Default Key Problem
Thanks for the reply LR. The key is supposed to be one that came with the truck. The blade fits, but the keyless entry doesn't work and it won't start the truck. It will fit in the ignition and the lights come on, but no start. I ordered the funky battery with the tangs on it and soldered it in (after removing the old one) - these are the switch blade keys. Still no luck. I checked and it has voltage. I just hate to go to the dealer and pay through the nose for a new key. It seems like nobody fixes these things. ;^(
Deutsch100
Oct 30, 2016 01:21 PM
russcan
Feb 10, 2008 10:27 AM
ioweyoumoney
Sights N Sounds
Jan 5, 2008 02:57 PM
emxracer
May 1, 2007 11:00 PM
alimohd11
May 7, 2006 04:37 AM
