RR4.6HSE 1997 popping through intake.
Old Jan 22, 2008 | 03:17 PM
Savannah's Avatar
Default RR4.6HSE 1997 popping through intake.
Have a Range Rover 4.6 HSE 1997 that idles fine,untill you touch the gas pedal.The revs falls dramatically before it picks up,after its popped through the airfilter.No faultcodes comes up.Smells like its running quite rich.Any suggestions?
Regards
Marius.[&o]
Old Jan 22, 2008 | 03:57 PM
WolfPack's Avatar
Default RE: RR4.6HSE 1997 popping through intake.
Could be a dirty air filter, but that would most likely trip a code, possibly an oxygen sensor? How many miles on your Rover?
Old Jan 22, 2008 | 04:26 PM
fozzybr's Avatar
4th Gear
A couple months ago, I had a similar issue and it was the fuel pump. Works good sometimes, then doesn't. Have the fuel pressure checked. Mine was showing about 20psi - way too low. This will cause all kinds of problems in that the O2 sensors and ECU are going to read erratic behavior / low fuel pressure and attempt to supply more fuel as a correction. At some point, this will trip a fault code. In my case, the check engine light would only come on every few days, and except for the last pressure test, showed 30psi. I also got rid of the K&N air filter and cleaned out the MAF sensor.
Hopefully, your issue is something in between. A faulty O2 sensor is much cheaper than a fuel pump or MAF sensor.
Mike
Old Jan 24, 2008 | 03:44 PM
Savannah's Avatar
Thanx for the reply guys.Turned out to be a faulty throttle position sensor.
Regards
Marius
coldstart
Mar 9, 2014 07:08 PM
Stan Pittman
Jul 14, 2012 05:13 PM
96SILVERDISCO
Jan 10, 2009 07:22 AM
birdhunter61
Oct 6, 2008 09:04 AM
Savannah
Mar 15, 2008 02:30 PM
