Squeal/Sqeak/Squak
Old Jul 1, 2008 | 11:34 PM
wess98range's Avatar
8th Gear
Default Squeal/Sqeak/Squak
I believe I have two problems, first one when accelerating I get a squeal that used to be only when I reached 30mph but now it is constant. It is extremely loud when I take my foot off the accelerator on a downhill. Also when I am driving any faster than 55mph and I get to like an equalibrium with the accelerator the car starts to almost grind beneath me and vibrate very loud. I believe its a u-joint? Now for number 2, when I am turning at slow speeds I get a squeal/squaking noise that almost sounds like its coming from near the drivers front wheel? I have not had any work done to it to make this noise occur, totally random. Please help. Thanks.
Old Jul 2, 2008 | 09:11 PM
roverguy7's Avatar
Default RE: Squeal/Sqeak/Squak
what year man??
Old Jul 3, 2008 | 02:05 PM
8th Gear
I have a 1998 4.0 with 137k miles. I also just changed the differential fluid and im not sure if that caused it to quit squealing or if when i got under the car to see if there was play in the front propeller shaft i wiggled it and it got stuck and the squeal has gone away but now when i turn at low speeds there is a rapid clunking noise, and vibrations almost like a grinding underneath me when im driving.
Old Jul 3, 2008 | 05:31 PM
roverguy7's Avatar
sounds like at axle shaft, they have constant velocity joints, if it goes bad youll get a clunk when turning, figure out what side and replace it, dont let it go too long as to itll cause major trouble if it brakes
andrewmcoffin
Mar 1, 2009 02:57 PM
morfa
Oct 31, 2008 07:16 AM
Aquaholic
Mar 16, 2007 03:05 PM
mike.howard
Jul 3, 2006 07:27 PM
BigMike
Mar 30, 2006 09:45 PM
