SRS light / Airbag fault
Old Sep 8, 2009 | 12:02 PM
mike031's Avatar
6th Gear
Default SRS light / Airbag fault
Have an '01 RR. SRS light just came on along with the "Airbag fault" warning.
I've read that there are yellow connectors underneath the driver's chair that might be loose and/or connectors behind the inside of the glove box.
Two questions -
1. Are the connectors yellow in my '01?
2. If this is the case, how would I go about finding the connectors behind the glove box?
Thanks!
Old Sep 8, 2009 | 01:15 PM
krazzz's Avatar
I'm glad you asked this question because I am having the same problem too. I looked under my seat last night and found two white connectors but no yellow ones. How many pin connectors should they be?
Old Sep 10, 2009 | 11:22 AM
mike031's Avatar
6th Gear
Default Yellow plug was the solution
Simply found the yellow wire connector under the driver's seat, pushed it together (even though it already felt tight) and boom, no SRS alert...
Old Sep 12, 2009 | 06:15 PM
val's Avatar
val
Unhappy srs
spend half an hour looking for yellow connector cant find it can you be moore specific were is it thanks
Old Sep 14, 2009 | 10:01 PM
krazzz's Avatar
Has anybody tried using dielectric grease to help this connection?
Old Sep 20, 2009 | 09:15 AM
wilson96rr's Avatar
I could be wrong, but I don't think all Range Rovers have these yellow connectors. I have tried to find the connectors on my 1996 p-38 model but they are not there. I believe they are only there for vehicles that have the side air bags. My SRS light has been on since I bought my RR. If I have this wrong, could someone please let me know. I would love to extinguish my SRS light. And yes, Krazzz, dielectric grease works very well to improve/protect electrical connections.
Old Sep 20, 2009 | 01:34 PM
ldivine's Avatar
My 2000 Rover's SRS connector is black. Not yellow. And it does have side airbags.
Old Dec 14, 2009 | 02:18 PM
revscpa's Avatar
7th Gear
Default Thanks for yellow connector advice
This is Dec 09 and I saw this thread and it worked! I have a 2001 Range Rover and the passenger side under seat yellow connector was just barely closed but not completely. Now, no SRS and no Airbagfault. Thanks much
vince
Old Dec 14, 2009 | 02:38 PM
Baylink's Avatar
One followup note: if you have this problem, and you are pretty sure you have the right connector, it can be worth unmating and remating it, even if it seems tight. Oxidation on the contact point can be causing the problem, and the wiping action of the pull-and-reseat can clear it.
Old Feb 10, 2010 | 10:46 PM
alankd's Avatar
Talking Yellow Plugs
I have a 2001 RR HSE. I had the SRS airbag fault message and continually connected the yellow plug under the driver's seat without any results. I discovered there was a yellow plug under the passenger's seat as well. After disconnecting both and reconnecting both the problem was solved.
