SRS light / Airbag fault
Old May 24, 2010 | 11:16 AM
Walter's Avatar
Thank you all,
Disconnected and reconnected both driver and passenger yellow connectors. Also found that dealer service had left the driver side "unhitched" from its clip under the seat -- like some step-child. Thus, I suspect, every seat movement or "nudge" created the difficulties.
2000 RR Holland & Holland #34 - 96,000
Old May 24, 2010 | 02:24 PM
POTBUT's Avatar
3rd Gear
All srs components have yellow connectors, or yellow sleeve or yellow conduit to id it as a srs system component. I have cleaned 100's of these connectors with contact cleaner.
Old May 29, 2010 | 02:52 PM
mlhoenig's Avatar
I have the same SRS warning light problem with my '99 Disco...along with the Anti-Lock light.
Anyone know if there's a single point of failure, as in the brake lights/PARK lock pairing...?
TIA!
Michael
Old Nov 2, 2018 | 02:43 PM
Locksley's Avatar
Is it safe to be fiddling with these connectors with the battery connected? or do i have to disconnect it. Ive heard that disconnecting the battery can cause problems, and necessitate a trip to the dealership to reset the charging system in the computer. thoughts?
L
Old Nov 2, 2018 | 10:41 PM
Jagfixer's Avatar
I am on my 4th Rover, Classic, D1, P38 and now LR4, never had to reset after unhooking battery.
lr3_ovrlnd3r
Apr 10, 2016 09:12 PM
punkarockaboy
Feb 15, 2012 05:32 PM
tonymac
Nov 2, 2011 12:50 AM
6RedRover9
Sep 25, 2010 02:34 PM
NATEDOGG
Oct 14, 2009 03:27 PM
