SRS Light and HAC on/off Knob
Old Nov 18, 2008 | 12:12 PM
twenspirited's Avatar
5th Gear
Default SRS Light and HAC on/off ****
Hello everyone,
I'm new to the site and new to owning a RR. I just purchased a 99 HSE RR and after enjoying the ride for a couple of days, I'm experiencing some problems.
1. The SRS light is on - Airbag Fault light is displayed. I've read that there maybe a wire connection lose under the seat - which I remember knocking the cover off located underneath the driver seat. So, I'll check that. However, if anyone else have any suggestions, I would be grateful.
2. When I try to turn the HAC unit off the **** just turns but its still running. I'm not sure whats up with that....LOL Any suggestions?
I purchase this vechile as a second car to ride for fun.
Old Nov 19, 2008 | 10:30 PM
ldivine's Avatar
Default RE: SRS Light and HAC on/off ****
Hello,
The SRS warning is most likely the wire under the seat (like you indicated). Seems to lose a connection quite often when the seat moves.
For the HVAC turn the **** all the way down then hit the A/C buttion on the far right at the top (an amber light should light) and then turn the **** again. Should completely shut off the A/C
Hope your enjoying the Rover and best of luck!
Old Nov 20, 2008 | 08:58 AM
There are about a dozen reasons for the SRS light to be on, anything from a low voltage issue to a total failure.
You should get it in and have it scanned for the actual problem.
Old Nov 20, 2008 | 04:11 PM
5th Gear
Thanks to the both of you! I did check under the seat and the ensured everything was connected. Long be hold, the light went out. And, I was able to the turn the HAV unit off.
Thanks again!
turbodave
Mar 29, 2019 07:22 AM
unpolire
Oct 3, 2014 06:53 AM
cosmiccharlie
Mar 13, 2013 07:57 AM
bcolins
Jun 10, 2011 11:36 PM
Chrisinhouston
Nov 16, 2007 09:59 AM
