on stop light car shake alittle
Old Nov 21, 2009 | 10:14 PM
wease206's Avatar
Angry on stop light car shake alittle
98 RR why does my car shake alittle on a red light
idle shake under 1000 rpm on a stop
step on gas car run fine
last time i had my spark plug, spark plug wire,
change 95k
now 133k
Old Nov 22, 2009 | 12:24 AM
LRScott's Avatar
Does it do it when it is warmed up, cold, or all the time?
I would replace your spark plugs, it is recommended that they be replaced every 30k miles, and yours are at 60k. I would also replace the spark plugs too, make sure you use 8mm magnecores. If that does not help, I would suspect MAF or O2 sensor, and possibly the fuel pump.
Old Nov 24, 2009 | 10:20 AM
handsome rob's Avatar
Mine does it too, we had a discussion on this a while ago. I can feel mine in the drivers seat but the engine is running as smooth as butter. Not really sure why it does it but it does. I would do what LRScott says since you need it anyways and see what happens. If you do that and the engine runs smooth then maybe your is just like mine.
CapeRover
May 3, 2013 04:35 PM
SSchultz
Nov 11, 2012 11:04 AM
jeffh
Jan 20, 2011 12:35 PM
johnnybob06
Oct 10, 2007 10:50 AM
