Strange License Plate Bulb in my 04 Range Rover
Old Jan 16, 2015 | 09:11 AM
micq's Avatar
8th Gear
Default Strange License Plate Bulb in my 04 Range Rover
I have the License Plate Bulb warning and one of my bulbs is out so I finally decided to do something about it. I checked both and yes 1 is out but when I pulled the bulb it is different from the one at Land Rover, Advance Auto, Online. Land Rover dealer told me they never saw such a bulb. I am tempted to purchase the Land ROver bulbs today but they are almost twice as long and do not have the grooves mine do.
I have attached the bulbs pictures to this post. any help on where I can find these exact replacement bulbs would help, It says made in Hungary.
Small yet annoying message but appreciate the help. Love my Range Rover!!!
Attached Thumbnails Strange License Plate Bulb in my 04 Range Rover-img_20150116_100218983.jpg   Strange License Plate Bulb in my 04 Range Rover-img_20150116_100204561.jpg
Old Jan 16, 2015 | 11:57 AM
OverRover's Avatar
Unless my memory is completely F'd, isn't the plate bulb supposed to be #CZQ000010 12v/5watt Festoon style?
Bulb 12V 5 Watt License Plate Light (Genuine Part # CZQ000010 ) - Land Rover bulbs from Atlantic British
Old Jan 16, 2015 | 11:43 PM
micq's Avatar
8th Gear
Yes that is the bulb its supposed to be I'll try it instead and let you know if it's a fit.
Old Jan 17, 2015 | 09:06 AM
OverRover's Avatar
Unless the bulb socket looks like this > https://www.superbrightleds.com/more...FY-JaQod4UkA3w the Festoon style bulb will NOT work.
The bulb base you have is mini bayonet style & almost looks like this > Light Bulb License Plate Lamp (5378 Same Fit As Part # 570822 ) - Land Rover bulbs from Atlantic British
Check the rest of the markings on your bulb, the base # could be there. Something like t2 or t3.
If you have to match the bulb from the OP go to NAPA and search "License Plate Light Bulb" and match it up. I looked, they have them.
NAPA AUTO PARTS - Home
Old Feb 11, 2015 | 10:18 AM
micq's Avatar
8th Gear
OverRover thanks for the input, Still trying to locate will give you an update if I have success!!
Old Feb 21, 2015 | 03:18 PM
micq's Avatar
8th Gear
Default Found License Plate Bulbs but still recieving the bulb error
So I managed to find the license plate light bulb for my 2004 Land Rover Range Rover at my Local Napa Store. The manager quickly knew he had the bulb and it costs $15 each. I previously removed both bulbs so it would not look like I had a light out. The bulbs fit and after restarting the car I still received the license plate bulb message and after checking the new bulb lights are out. I know they were previously both working.
Is it possible I may have blow a fuse or damaged something while driving for a month with no bulb in the sockets? I have had recent small electrical issues.... My car alarm going off at Random, and recent suspension inactive occurrences ( which I assume are the suspension and not electrical). Other than that not sure why the new bulbs are not illuminating and I'm still seeing that issue.
Any insight is much appreciated!
Attached Thumbnails Strange License Plate Bulb in my 04 Range Rover-license-plate-bulb-range-rover.jpg
cdebari
Jun 5, 2011 04:55 PM
ajh
Oct 10, 2007 10:16 PM
underpsi
Jan 15, 2007 01:20 AM
RDM3
Freelander
Dec 15, 2006 04:56 AM
KWAYZ
Dec 7, 2006 09:09 PM
