windows wont open
Old May 18, 2008 | 03:50 PM
losbadgt's Avatar
3rd Gear
Default windows wont open
i have a 1997 rr 4.0, and the battery went bad so i got a new but my windows, sunroof and side mirrows wont work? and when i turn on or off the car its says that my windows are not set? what does that mean and i check all the fuses and nothing.
Old May 18, 2008 | 04:03 PM
roverguy7's Avatar
Default RE: windows wont open
with the windows up. put them down and then back up, all the way, without letting off the switch, one at a time. youll also need to set your sunroof, ame basic thing, closed, all the way back, then closed then tilt up... itll say window/sunroof set on the i/p if it works
Old May 18, 2008 | 04:25 PM
WolfPack's Avatar
it's all outlined in the owners manual if you have it
Old May 18, 2008 | 05:01 PM
losbadgt's Avatar
3rd Gear
i try to do the whole holding the buttows and nothing, they wont go down or up. even my side mirrows wont more at all.
Old May 18, 2008 | 05:23 PM
roverguy7's Avatar
and all you did was disconnect the battery?? and it was all working fine before that?
Old May 18, 2008 | 05:24 PM
WolfPack's Avatar
Do the gauges and everything else work fine? What about interior/exterior lights?
Old May 18, 2008 | 07:04 PM
losbadgt's Avatar
3rd Gear
everything is working fine just the windows sunroof and side mirrows dont work, and yes everything used to work fine before the battery died.
keithd21
Aug 2, 2012 07:14 PM
snownice
May 20, 2009 03:32 PM
bhorwhat
Oct 16, 2007 10:14 AM
dmm698
Aug 28, 2007 06:37 AM
