Tailgate lights out only
Old Dec 30, 2009 | 09:55 PM
fire57dan's Avatar
Default Tailgate lights out only
I have a message in the message center that says left brake lamp failure. The lights on the fenders both sides are good as well as the third brake light. My problem is the tailgate lights are out, all of them. I prodded the wires in the tailgate and the only ones hot are associated with the latch. I popped off the trunk panel on the right side, and the wire dissapears? I'm assuming it goes to the Body control module under the seat but am not sure. Do the tailgate lights have their own fuse? or do they splice into the other wires for lights?
Any help is greatly appreciated.
Old Dec 31, 2009 | 01:02 AM
LRScott's Avatar
That is a really odd issue, I would check the fuses first, as they are most likely the cause. A simple reset might fix this problem as well. What kind of voltage are you getting?
Old Jan 11, 2010 | 11:17 PM
fire57dan's Avatar
The reverse lights work but the two others dont. There are 0 volts going to the two other lights. I replaced both bulbs and no change. I don't know if they are marker lights or brake lights. I took out and reinstalled all the fuses in the Becm and none of them were blown.
Old Jan 12, 2010 | 06:26 AM
wilson96rr's Avatar
Those are your rear fog lights. The switch is on the dash next to the front fog lights. I believe the key has to be in the on position and the headlights on.
Old Jan 13, 2010 | 03:37 PM
fire57dan's Avatar
I would have never guessed. I thought they were marker lights that were on all the time when the lights were on.
rreinholt
Oct 10, 2013 08:47 AM
Classklown90
Aug 24, 2010 04:26 PM
Kai
Jul 16, 2010 09:55 AM
VikingDiesel
Dec 29, 2008 11:40 PM
dhaselhorst
Jun 27, 2007 04:57 PM
