Testing a Fuel Pump (90RR)
Old Mar 27, 2008 | 05:12 PM
houstonhelix's Avatar
8th Gear
Default Testing a Fuel Pump (90RR)
Could someone advise on how to test to see if the fuel pump on my 90RR is functioning?
Thanks!
RON
Old Mar 27, 2008 | 07:24 PM
cst756's Avatar
Default RE: Testing a Fuel Pump (90RR)
You should be able to disconnect the fuel line (at what point in the line I don't think it will matter) then switch the vehicle on, you should not have to crank it just turn to the ACC position, this should activate the pump and shortly afterwards gas should begin to pump out of the fuel line.
Old Mar 27, 2008 | 07:30 PM
cst756's Avatar
If you don't like this idea when you turn to the ACC position you should be able to hear the pump, pumping fuel.
Old Mar 27, 2008 | 08:04 PM
8th Gear
I can hear the fuel pump if that what it is - the buzzing sound that runs for about 6 seconds when the ignition is turned. However, I am tryiing to diagnose if the fuel is actually getting pumped all the way to the injectors or if it is clogged at the fuel filter. Thanks again for your input!
Phatrowles
Feb 12, 2025 10:29 AM
Travelor
Sep 24, 2015 06:11 PM
wheelgarage
Dec 3, 2011 04:59 PM
JumPeR04
Apr 7, 2011 09:52 PM
houstonhelix
Mar 16, 2008 08:54 AM
