Tie Rod End Help?
Old 09-16-2012, 08:35 PM
Cottrell's Avatar
Default Tie Rod End Help?
Newb here (and possibly a dumb question) but I was just wondering if this is the short end or the large end of the tie rod that I need to replace. It is on the drivers side of a U.S. model (Don't know if that matters, but I thought I would include it.)
Old 09-16-2012, 09:55 PM
Rovin4life's Avatar
Its the tie rod end you need. around thirty bucks.
you just need to reclean up the threads to make sure the parts will turn. you might need a torch and a pickle fork to get it off.
Old 09-18-2012, 03:12 AM
Cottrell's Avatar
Thanks I appreciate the help. Now, does anyone have any idea what the gap between the front tires should be for alignment?
Old 09-18-2012, 08:38 AM
LR Techniker's Avatar
The tolerance is too tight to use a tape measure. The best you can do, is use a tape measure to get it "close" so you can drive it to get it aligned.
Take measurements before disassembly to use as a reference.
Old 09-18-2012, 03:27 PM
Cottrell's Avatar
Too bad I can't get away with doing it myself $$ Thanks for the wisdom.
Old 09-18-2012, 05:47 PM
Well, to answer your question, the distance between the front of the tires should be 0.02"-0.07" more than the rear of the tires (toe-out).
Tape measures and string are usually best left for off-road only.
Old 09-19-2012, 04:54 PM
Ringo's Avatar
I counted the number of exposed threads on the old one and put the new one in using that as the measuring distance. When I took it in for an alignment one side was close, the other was off. Don't skip the alignment, its worth it, saving the tires and gas mileage.
Old 09-20-2012, 01:24 PM
Cottrell's Avatar
Copy all guys, thanks for all the help.
TRIARII
02-21-2013 10:33 PM
Clunker
05-09-2011 08:16 PM
Christian_X
10-27-2008 05:54 PM
cbwhitley
05-29-2007 06:44 PM
jcw
10-27-2006 08:26 PM
Quick Reply: Tie Rod End Help?
