Timing chain kit.
Old Sep 11, 2011 | 11:16 AM
Osiris's Avatar
Default Timing chain kit.
Hey guys,
New here, hope this is in the correct place. I just got a '97 as a project. I was replacing the crankshaft seal when I decided, why not just drop the oil pan and remove the oil pump housing to check the timing and components.
So the chain is very loose and I am going to replace the gear set and chain as well. I came across this kit but it looks like it is for '99-'02 P38's only. Is there something like this compatible with the '97? It looks like just the oil pan gasket that is not compatible with my year, I'd hate to just have a wasted part. Thanks in advance.
Timing Chain Kit (BOSCH Engine) | Land Rover Engine Parts at RoverParts.com
-Marc
Old Sep 11, 2011 | 01:33 PM
Not sure as to the specific part number chain set to us, just wanted to suggest you also replace the oil pump if you are at 140,000 mile or above.
Old Sep 11, 2011 | 01:37 PM
Osiris's Avatar
Thanks for the advice Disco Mike. I will look into replacing the pump as well since I am at 167k. Do I need to replace the entire housing or just the oil pump gears?
Old Sep 11, 2011 | 01:52 PM
Take a look at this post with pix, https://landroverforums.com/forum/di...-instal-43603/
Old Sep 13, 2011 | 01:48 PM
Osiris's Avatar
Thanks Savannah, that was a good read.
I just got finished replacing everything last night. Going to drop the radiator back in after work and fire it up and see what happens.
A5scott
Jul 11, 2015 07:25 PM
Martin Rodriguez
Feb 25, 2014 08:55 PM
91rover
Dec 7, 2007 06:53 PM
FTB 2000 Disco
May 15, 2007 07:49 AM
mrach21061
Apr 25, 2007 11:54 AM
