Today's Problem! Stammering under initial acceleration.
Old Aug 25, 2010 | 09:49 PM
AustinMiniMan's Avatar
Default Today's Problem! Stammering under initial acceleration.
A couple weeks ago I kept getting a check engine light indicating that I had a bad throttle potentiometer. I tested the pot and it checked out, but the wiring to it was pretty knackered. So I spliced in the pig-tail from my parts car, and everything was fine.
Today I went to drive it, and I did my standard procedure of taking a couple laps around the block to make sure everything was kosher and to let it warm up. It seemed fined, so I pulled onto Main street. After a bit I went to turn left, and when I applied any throttle from idle it stammered... it acted like it had completely leaned itself out. It didn't jerk or anything, it simply had no power at all. I turned around and made it back home, but it did the same thing several times. If you floored it it would stammer and then slowly regain its wits and drive fine after a roughly ten second delay, but it didn't like starting from a standstill.
It didn't throw any codes; no lights came on at all and it was idling fine. Thoughts?
Old Aug 25, 2010 | 09:58 PM
LRScott's Avatar
What year is your rover, and how many miles?
Old Aug 26, 2010 | 02:34 AM
Oops... sorry about forgetting to include that. It's a '90 and has around 110k miles.
Old Aug 26, 2010 | 10:16 AM
LRScott's Avatar
You could try cleaning your MAF sensor. That might make a difference. Plus the can of spray is only like $7 .
Old Aug 26, 2010 | 10:25 AM
handsome rob's Avatar
I would check the MAF as well first, chances are it is dirty and or even the connector is loose. I would also look at maybe some O2 after that.
Old Sep 2, 2010 | 04:55 PM
Vertigo RT's Avatar
I just had this issue about a week ago, and indeed, it was a bad MAF, changed it out. 100% better!
AJ Mac
Aug 26, 2013 01:02 AM
Triple
Oct 18, 2012 09:36 PM
nelsontod
May 19, 2012 09:25 AM
cgee
Feb 3, 2008 02:24 AM
kerbse
Jul 2, 2007 11:09 AM
