Trailer wiring harness
Old May 8, 2005 | 02:44 AM
PedroNole's Avatar
3rd Gear
Default Trailer wiring harness
Hi all!!
I'm a new owner of a '01 Range Rover. I was shocked when it didn't come with a trailer wiring harness but got over it and bought one and installed it myself. Install went great until I started the car and shorted out a 30amp fuse that runs A/C, Navigation unit, radio, etc. I cannot understand what I'm doing wrong. Helpppppp !!!
Old May 8, 2005 | 12:44 PM
95 classic lwb's Avatar
6th Gear
Default RE: Trailer wiring harness
How did you wire that in? I just installed a trailer wiring kit on my '95. I pulled the tailights out, used a test light to find each wire that I needed (needed 1 brake, 1 right turn, 1 left turn, 1 ground, and one just 12v.) The kit I installed was from U-Haul and it went in with about an hour worth of pulling the lights out, probing wires, putting on the splices, and then hanging the wires so it looked nice. I would guess that you probably have a ground and a brake or 12v switched.
Did the fuse blow right away? Did it blow when you used turn signal or brake?
Old May 8, 2005 | 11:21 PM
PedroNole's Avatar
3rd Gear
It blows right away after starting the car up. I bought and installed the factory OEM kit from the dealer. I followed the instructions explicitly...even the part where they supply a 15 amp fuse to replace the 20 amp factory fuse for the rear trailer/lights, etc. It seems odd to go down in amps but ok I did it. The fuse that blows is the 30amp that controls the A/C, navigation, radio, etc.
Old Jul 2, 2007 | 07:54 AM
tjd's Avatar
tjd
Did you ever solve this problem? I just bought the same kit and I am having the same exact problem.
Sharpfocus
Nov 18, 2008 05:46 PM
MiniManiac
May 21, 2007 08:55 AM
bbensten
Aug 5, 2005 03:52 PM
PedroNole
Jun 28, 2005 12:50 PM
