Tranny Crapped out
Tranny Crapped out
Well, I had the truck running just great after I did the unmentionable swap of the 4.0 in place of the 4.6. Today though while driving on the freeway at 70 with the cruise control on the tranny just stop driving. The truck coasted to the side and I was not able to select any gear option. There was no noise, surge or anything just the engine revving. Got ti towed to a local shop and of course they said they cannot read anything. Do you have any ideas as to what happened? The tranny has 132K on it and I double checked all the sensors on the side of the road and nothing fixed it.
Is this something that may be a common fix or do I now have to do a tranny as well?
i think youre right, it is the front pump, i have a question... did you swap the flywheel and flexplate from the 4.0 to the 4.6??? if not then... it will go again if you just change the pump. one of the things that most people leave off from doing this swap is the difference between the engines... the flywheel exactly. the 4.0 has a 12mm spacer between on the flywheel and the 4.6 has only a 4mm spacer, its there because the trans that came in the 4.6 has a bigger torque convertor. what happend to you was your torque convertor has been shoved back 8mm putting a lot of stress on that pump, and ruining its housing. when the trans is out, swap the flywheel, or replace the convertor... either way, make sure to check the ears on the convertor for wear and stress cracks
I swapped the ring gear that was on the 4.6 to the 4.0, I did not swap over the plate that has the tone ring though, is that what you are talking about? Can you put in a different torque converter? Unfortunately I am about 980 miles form the other engine when the tranny went out so it will not be that easy to get the other peice off the old engine.
Looking on online I see the different spacers. The flywheel itself is the same but the spacer that attaches to the crank flywheel adapter and then to the flywheel is where the difference is at.
So basically I was pushing the torque converter back into the tranny and caused the stress on the pump. I do not want to do that again. I am going to see if I can find one here locally to do it, or otherwise I will just head home and then come back with it and get it done.
Roverguy7, let me know if there may be anything else that I missed when I did this that may cause a problem. I tried lookng through all the other parts to see if there was anything and I did not see anything that jumped out.
Thanks.
Thanks.
yes. and a t/c for a 4.0 would do the trick, but they cost about the same as a whole tranny if i recall, at least through rover, and youd still need the front pump... as to the spacer, rover part number for the one you need is FTC4609, assuming i didnt get this backwards, but thats the one that should be on a 4.6.
Danan Coleman
12-14-2013 05:31 AM
Bryan H
07-25-2010 07:15 AM
