Transer case fluid
Old Aug 22, 2012 | 04:12 PM
crznmyway's Avatar
Default Transer case fluid
What kind of transfer case fluid do you use in a 2000 range rover hse and how many qt thanks cruz
Old Aug 22, 2012 | 05:27 PM
If dry, 5 pints, if refill, 4.2 pints. Both of these are US measure. If in the UK, also pints for all the lads helping out.
The RAVE shop manual says Dexron III ATF for the transfer box, this is different from Discos.
Old Aug 22, 2012 | 09:32 PM
LRScott's Avatar
This is correct. However, in the past some of our members' owners manuals state that there should be gear oil in the transfer case, and when they drained it to refill it, gear oil is what came out. A transfer case is not as complex as a transmission so it should do fine on gear oil or transmission fluid, but I would replace the fluid with what comes out and not mix them.
Old Aug 23, 2012 | 06:36 AM
Yes, but viscosity of gear oil is a lot "diff"erent than transmission oil. Not uncommom for people with older TC in a D1 to run 85W150. Perhaps a pro will rest his wrench for a moment and comment.
Old Aug 24, 2012 | 08:30 AM
crznmyway's Avatar
Didn't know for sure I had to go out and get a rebuild one so dont know what was in it so does it matter if its trans fluid or gear oil thanks cruz
Old Aug 24, 2012 | 08:50 AM
For the diffs, an 85/140 gear oil is the new HD standard.
As for the t/case, I believe Rover changed there recomondations over to gear oil also, if so, use the same 85/140 be it regular oil or synthetic is your choice but I always recommend synthetic for better wear protection.
Old Aug 24, 2012 | 06:15 PM
threalassmikeg's Avatar
All Land Rover Borg Warner Tboxes use Dexron3
Old Aug 31, 2012 | 02:27 PM
crznmyway's Avatar
Thanks Guys for all the help
Athana
Jun 8, 2019 10:23 AM
Rolltop
May 5, 2014 09:17 AM
1998DiscoverySE
Jul 20, 2012 08:02 PM
shoppinit
Sep 16, 2010 05:06 PM
LRScott
Mar 4, 2009 08:39 AM
