Transmission Chain
Old Dec 23, 2011 | 09:13 AM
Robert John Langdon's Avatar
4th Gear
Angry Transmission Chain
I have a P38 1997 4.6 HSE - 4 speed Auto.
After 110K the Transmission chain 'stretched' so that loud clonking noise could be heard when accelerating from a stationary position or on a high gradient - it seems these chains are good for 70K.
I have used the new chain for 2 months doing just 2.5K miles and its gone again!!
Is it possible that its a faulty chain or is this a symptom of something more?
Bob
Old Dec 23, 2011 | 09:47 AM
The tranny does not have a chain. What are you referring to.
Old Dec 23, 2011 | 09:51 AM
4th Gear
Default Range Rover Classic Chain - Borg Warner
Admin
Range Rover Classic Chain - Borg Warner at www.rimmerbros.co.uk
Thanks!
Bob
Old Dec 23, 2011 | 10:25 AM
Thats for a t/case, not a tranny.
Old Dec 23, 2011 | 11:18 AM
jafir's Avatar
Lucky8 Llc. - Take the road less traveled...
jafir's Avatar
1995-2002 Range Rover Transfer Case (4.0 SE & 4.6 HSE) (Professionally Rebuilt)
Old Dec 23, 2011 | 12:37 PM
4th Gear
Default Transfer Case!
Sorry as its called a 'drive chain' and its housed in the 'transfer box' you would imagine its something to do with the transmission, - but what do I know!
Thanks Mike, very helpful!!
Old Dec 23, 2011 | 11:18 PM
The engine turns the transmission the transmission turns the transfer case the transfer case turns the drive shafts the drive shafts turn the axle shafts the axle shafts turn the wheels.
Could be the gears (that the chain rides on) are worn to much and cant keep the chain tight.
Did you put the right fluid back in it after replacing the chain?
Some noise in the driveline is normal.
Old Dec 24, 2011 | 07:02 AM
4th Gear
Default Thanks Spike
I'll check with the garage to see if the chain had 'stretched' - like the last one - if not its probably the gears as you suggest.
Old Dec 24, 2011 | 09:51 AM
Make sure they are using the proper lube in the t-case, using the wrong lube will make it wear faster.
Defender90
Defender
Jun 28, 2007 11:31 PM
FTB 2000 Disco
May 15, 2007 07:49 AM
mrach21061
Apr 25, 2007 11:54 AM
thalpo
Aug 9, 2005 03:18 PM
garnstar
Aug 3, 2005 01:45 AM
