Transmission fluid flush/filter replacement
Old Mar 8, 2009 | 11:14 PM
LRScott's Avatar
Default Transmission fluid flush/filter replacement
I ordered a new transmission filter kit for my P38 and when it arrives, I would like to know what kind of ATF I should use. Normally I am not so cautious but, rovers are sometimes particular and its an expensive transmission...
That and I also bought some Lucas "Transmission Fix" in previous posts I stated my transmission has been making some weird noises and I thought it might be worth a shot, considering my other option is to rebuild the transmission when it finally does break. It says it is compatible with any ATF so I would assume it is ok but, I want some advice and make sure I do not damage anything because as previously stated, its an expensive repair if I mess something up.
Thank you all so much for your advice!
Old Mar 9, 2009 | 01:04 AM
ldivine's Avatar
RAVE has ATF Dexron III liste but a full synthetic should work too.
Should be fine with the additive. Whether it does what it claims or not you'll have to let us know.
comleader
Nov 28, 2024 12:23 PM
ghtaylor
Aug 30, 2020 04:20 PM
1998DiscoverySE
Jul 20, 2012 08:02 PM
wannabe
Jan 24, 2011 10:42 AM
tunernewb92
Jun 23, 2009 04:44 PM
