Transmission leak (bad)
Old Mar 12, 2011 | 02:52 PM
djmathis32's Avatar
Default Transmission leak (bad)
I have a 2000 range rover that has a bad trans. leak. It look like its coming from a hose but I can't really tell. Can someone help me. If they have had the same problem
Old Mar 12, 2011 | 08:26 PM
LRScott's Avatar
Leaks can come from anywhere. You need to determine where it is. It could be from anything that has a bad seal. Such as the pan gasket, cooler inlet and outlet lines. Get under it and pin point the leak.
Old Mar 12, 2011 | 11:22 PM
krazzz's Avatar
Get under there and clean everything up so you can see where the leak is coming from. I would use some degreaser and then hose it all down. It also helps to lay some cardboard under it so that you can see where the fresh drips are coming from. Mine had a bad leak after I replaced my filter. I removed the gasket and used RVT to make my own gasket and now no more leaks.
Old Mar 12, 2011 | 11:30 PM
handsome rob's Avatar
If you see the drip coming from a tube you may need to trace it up to the source. Cleaning it is the only way to pin point it.
dparham
Apr 22, 2013 04:03 PM
starcraft1
Nov 13, 2011 08:14 PM
oljohnboy
Sep 14, 2009 03:01 PM
rgrizzard
Mar 6, 2008 10:16 AM
Bene
ROAMING WITH FRIENDS
May 11, 2005 04:33 AM
