Transmission or somthing else
Old Dec 16, 2008 | 10:40 PM
ragnieloverhse's Avatar
Default Transmission or somthing else
I have an 01 Range Rover Hse, and when i am holding a constant speed, normally around 45-55 mph i get a type of shuddering, almost like the truck is choking or something, the revs go down a bit then go back up, i dont have any check engine lights, so im a bit confused, i was guessing the torque converter, but thats a big expense so any other ideas would be nice, also maybe the sparks plugs and leads?? any ideas would be appreciated
Thanks =]
Old Dec 17, 2008 | 09:43 AM
ldivine's Avatar
Default RE: Transmission or somthing else
Could it be the shocks? They cause a shaking/shuddering anywhere from 45-60 mph when they're blown. It could also be the ball joints or tie end rods.
Old Dec 17, 2008 | 01:44 PM
It won't be the torque convertor, you would have a check engine light on.
It certainly is not shocks.
I would suggest trying to make the engine throw a code.
PM me your tele number and I will be glad to walk you thru this.
bosshogt
Jul 9, 2011 09:35 PM
djkiddanger
Apr 8, 2008 05:21 PM
BYURover
Jul 18, 2007 09:00 AM
russ00001
Apr 26, 2006 03:51 AM
silence
Aug 20, 2005 10:54 AM
