airbag fault
Old Dec 13, 2008 | 12:58 PM
val's Avatar
val
Default airbag fault
I have a 1999 range rover, and the air bag fault is displayed on the message center. My horn, and stereo control buttons are working fine. Any suggestions of what happened.
Old Dec 13, 2008 | 07:18 PM
WolfPack's Avatar
Default RE: airbag fault
Did you check all your fuses?
Old Dec 14, 2008 | 02:31 PM
ldivine's Avatar
The airbag fault is very common... check under your driver's seat to make sure you don't have a loose connection. This is the number own cause of the message. Seems it comes loose with the bumps and such the vehicle endures.
Old Dec 17, 2008 | 02:02 AM
tacomatech's Avatar
I agree. Turn the ignition off, disconnect the battery negative lead, andleave it forabout ten minutes. Locate the yellow 2-wire connector under each front seat. Disconnect them and put a little di-electric grease in the connector and reconnect the connectors and then reconnect the battery. The faults should be cleared.
Old Dec 18, 2008 | 04:15 PM
twenspirited's Avatar
5th Gear
Val,
I had the same problem and did excatly what ldivinesuggested. The Airbag Fault went away. I happend again after I had the truck vaccumed, followed the suggestion and it went away. I'm tempted to just put some black tape around those wires...LOL
Old Dec 18, 2008 | 09:26 PM
ldivine's Avatar
Go for it! Electrical tape works well and you can always remove it later
06Range
May 8, 2013 09:01 PM
faheemf1
21
Feb 29, 2012 08:41 PM
mom2bekah
Apr 13, 2008 02:09 PM
wease206
Dec 26, 2007 03:24 AM
