Vibration issues 2005 RR Td6 PLEASE HELP
Old Feb 25, 2008 | 04:32 AM
kaimakliotis's Avatar
4th Gear
Default Vibration issues 2005 RR Td6 PLEASE HELP
I have some vibration issues on my 2005 range rover td6. While at standstill it vibrates when having foot at brakes . Has anyone outhere experienced the same problem.I have checked my driveshafts , everything ok. My car has 22 overfich rims. Someone told me that this might be the problem but i am not convinced. Also my steering wheel is abit heavey compared to other td6s so i think it might be the steering rack or steering pump . Can anybody help me.
thank you
Old Feb 25, 2008 | 10:40 AM
WolfPack's Avatar
Default RE: Vibration issues 2005 RR Td6 PLEASE HELP
Your steering is probably heavy because of the 22's...thats alot of weight to be turning. As for the vibration, do you feel it in the seat and body of the vehicle (rear end source), or through the steering wheel (front end source)? Also is it rpm related? Could be a bad IAC valve causing a low idle, and the vibration..just a guess though. Post up some more specific information and we'll go from there!
Old Feb 25, 2008 | 02:13 PM
4th Gear
hello there ..thanks for replying ... the vibration is strictly on the steering wheel ...but its is quite noticable on all the car.. i mean the passenger can notice it but of course only if you mention it to him .. i have tried a normal td6 ..that is with normal rims and it doesnt do the vibration. Also the vibration is only at standstill ...
Old Feb 25, 2008 | 02:15 PM
4th Gear
also rgarding the rpm ..i have tried to to accelerate a bit while hitting the brakes but it still does it ... it will stop i think over 1000 rpm .
pietch
Dec 2, 2008 10:44 PM
P Carr
Jun 15, 2008 05:02 AM
BONNER
May 17, 2008 07:58 PM
gebe
Nov 13, 2007 08:42 AM
p38spares
May 14, 2007 03:55 PM
