Wabco ABS 1990 RRC
https://www.dropbox.com/sc/6xqu6dteg108awn/NbVuxIRi7j
Now to find some brake line...
I repaired the line by thoroughly inspecting and cutting a good swatch and replacing with new line and compression fittings.
Yet now I am have a slow but consistent leak out of this unit pictured below, directly under the black trapezoid shaped plug.
That is the ABS Booster. When you bleed the brakes after the "repair" you might have added too much fluid to the reservoir. Check the fluid level. Too much can cause the brake fluid to leak from the reservoir cap and drip back towards the firewall.
Or another one of the rear brake lines are leaking near the firewall, under the booster.
Or one of the reservoir seals(there are 2) Land Rover Parts, Accessories and Information is bad causing the leak.
Also check the hose clamp on the hose that goes from the reservoir to the ABS pump.
NEXT: REPLACE ALL THE HARD LINES ON THIS RIG!!!!!!!!! Or have good Insurance!
I do know, the umm story of this rover is that it was given to me after sitting for 6 years by my next-door neighbor, just trying to get it up and running-
The developed pressures are in excess of 1500 psi.
Enough to blow the joint a part with potentially disasterous consquences.
T/V
aarongregor
12-01-2015 08:43 AM
aarongregor
01-16-2012 07:02 PM
dino109
01-01-2012 12:09 PM
