Water on passenger side floor
Old Feb 21, 2016 | 08:03 PM
arm222's Avatar
3rd Gear
Default Water on passenger side floor
07 Rover Sport has carpets soaking wet on passenger side floor. I checked the sunroof drains and they appear to be clear. Water runs right thru to the ground. Any other ideas of where it could be coming from?
Old Feb 22, 2016 | 08:26 AM
drowssap's Avatar
is it water or coolant?
Old Feb 25, 2016 | 04:28 PM
jeansonnelaw@yahoo.com's Avatar
If water, maybe the a.c. line blocked under the dash, OR sometimes water will sneak in under the windshield cowl from outside???
If coolant, ... heater core ... really bad !
Old Feb 25, 2016 | 05:33 PM
DavC's Avatar
if the windshield cowling is anything like the Discovery 3 it will cup right over the HVAC intake so water will go through there and you will have wet passenger side carpets.
Try replacing the windshield cowl and putting marine silicone between the cowling and the glass (or making a little silicone barrier over the HVAC intake so water goes around it).
Old Sep 17, 2017 | 05:30 AM
lucyf0rd's Avatar
7th Gear
Check the sunroof drain tubes as well. It is a common problem for RRSs and LR3s.
Old Sep 17, 2017 | 08:17 AM
Threads a year old but he said he checked those in the original post.
Lot of Zombies around today
MPDano
Feb 6, 2023 04:45 PM
MichaelDisc02
Jul 27, 2015 12:10 PM
dougn
Dec 4, 2012 06:25 PM
Princess
Sep 15, 2009 08:02 PM
rjaime6
Jul 12, 2008 10:53 PM
