Welcome Faymester!
Old Dec 24, 2008 | 06:49 PM
luxury1's Avatar
Default Welcome Faymester!
A big welcome to Faymester from Club Lexus
Old Dec 25, 2008 | 02:43 AM
Faymester's Avatar
Default RE: Welcome Faymester!
Thx luxury1. I'm excited about the new Rover.
Ok, so it's a 2003 Range Rover in the green/grey color w. off white interior. I'll try to get pix up soonish.
Problem right off the bat though so this scares me a little (since as of right now I've only had the car for 6hrs). The 'problem' indicator came on during the short drive home from dinner tonight. I assume it's the general problem light, between the spedo & tac, hazzard symbol with the circle around it. So I check the drive info centre and the screen isn't giving a clear read out. only the left side is working (so I guess I have two problems really). So it says, "Air Susp. more-words-that-only-kinda-show-up" & then "HDC other-hard-to-read-words".
Also (I don't have the manual just yet, I get it on Saturday since the guy left it at his house) how do you change the ride height? It wasn't immediately obvious to me.
Hmm, what a loaded first post from me that was.
Thx for the welcome again, hopefully this 'problem' turns out to be nothing.
Who else form CL is over here?
Old Dec 25, 2008 | 01:58 PM
Faymester's Avatar
Ok, I downloaded the manual and I think I've figured out what the indicator and driver info centre is trying to tell me and I think it's not a big deal. It seems like maybe we used 4-low too much and the EAS system over heated (?) and it should reset its self (?) I hope (?) ... Clearly I still need to have the driver info screen fixed/changed.
What I can't figure out is where the 'inhibit' button is for the EAS ride height selection, and further more what inhibit on/off is.
Old Dec 25, 2008 | 03:16 PM
luxury1's Avatar
To change the ride height, there is a switch in the center console near the shift ****. Forward for higher and backward for lower.
You warning light may because you have raised and lowered the car too much and the system is temporarily inactive due to overheating, it could be because of low tirepressure or something else. If it does overheat, it should reset itself (at least it does on my model).
For others, Faymester is a heavy contributor to my other forum (Club Lexus) and we are happy to have him as a member! As for your other question Faymester about CL members, I don't think there are any others out there. You are the first one on Club Lex to own a Range Rover as far as I have seen (and I have looked).
Old Dec 25, 2008 | 03:34 PM
Faymester's Avatar
Sweet thanks I thought I knew which it was but I didn't see it specified in the manual (maybe I missed it)
I've been reading the manual for a couple hours now on anything related to what my dash says. Rover has been sitting for the night so everything should be nice and cool; I'm going to go out and drive it around in a bit& see if the indicators are still there &/or if they will reset them selves (one part of the manual said stuff should reset within 25-minutes).
I think I might have overheated the compressor because I tried to raise it tothe off-road height but Rover didn't agree with my request so then I flicked it to lower to Access; I think I confused it. Maybe I can do it today.
Old Dec 25, 2008 | 08:04 PM
luxury1's Avatar
Mine doesn't overheat unless I use it a lot so it very well may be something else.
By the way, congrats on the new Range! I know how excited it is to get your first Range Rover and it is a memory that you will never forget. There will be some issues here and there but you will LOVE it!
Old Dec 25, 2008 | 08:36 PM
skyguy's Avatar
Feymester, the height switch should be automatic when @ highway speeds it lowers, access mode is only used when you are stopped. Off road height is only when off roading. The height difference is subtle mostly for performance. On my p38 you can lock the ride height and keep it from changing. Welcome to the club hope you add as much as Lux 1
Skyguy
Old Dec 26, 2008 | 02:17 AM
Faymester's Avatar
Thx for all the help guys
I've got it now & everything is quite brilliant. Drove through & over some minor things today.
I'm quite loving the Rover.
Off Topic
Aug 10, 2006 07:38 PM
Off Topic
May 12, 2006 05:01 PM
Off Topic
Dec 16, 2005 03:44 PM
Off Topic
Oct 11, 2005 11:30 PM
Off Topic
Jun 8, 2005 09:57 PM
