Range Rover 4.6l leaks coolant at the back of the block!
Old Dec 26, 2008 | 01:36 PM
psingh's Avatar
Default Range Rover 4.6l leaks coolant at the back of the block!
Hi guys,
I bought my first Land Rover in May 2008. I love my truck but lately it is starting to giving me trouble. First my drivers side door jammed and is sealed shut. I have tried opening that but the locking mechanism seems jammed. Any suggenstion on that. My latest problem that my heater was not blowing hot air so I decided to check the coolant level in the resevoir tank and that showed low. So I filled it up and driving down the freeway it started to over heat. I caught it right when the temperature start to move up so I placed the transmission in neutral and shut off the motor so it would not get abused. The gage however it hot just fora second before I shut off the engine. I filled the truck back up with coolant and water mixture but now it is leaking. I check the engine block and I see there is a small leak from back of the block right above the passenger side exhaust manifold. It seems like it is coming from the Valve Cover gasket but I can't really tell as it is from the back of the block. Any ideas what it could be?
Old Dec 27, 2008 | 02:18 PM
ggothlin's Avatar
Default RE: Range Rover 4.6l leaks coolant at the back of the block!
Well, it could be a head gasket leaking, now you could try one of the better sealers in your antifreeze, dealer will probably charge around $1200.00 give or take to change the head gasket, you will save money if you can find a good mechanic that works on the side
Good luck.
Spencerfitch
Sep 27, 2020 12:17 PM
humroot
Jul 22, 2019 06:33 PM
FlyingZebra34
Apr 22, 2013 12:07 AM
discoboy
Dec 20, 2012 02:24 AM
audiS4S6
May 12, 2010 09:15 AM
