While changing plugs I saw these
Old Jun 30, 2012 | 07:28 PM
Bishop's Avatar
Default While changing plugs I saw these
I was putting in new spark plugs today and noticed these two ports open.
should they be plugged or plugged into something?
It's a 98 RR 4.0 SE
Here's a pic of both.
I did have the air bags removed and springs installed last year by the dealer.
Attached Thumbnails While changing plugs I saw these-picture-026.jpg   While changing plugs I saw these-picture-027.jpg   While changing plugs I saw these-picture-024.jpg   While changing plugs I saw these-picture-025.jpg
Old Jun 30, 2012 | 09:31 PM
XCELLER8's Avatar
the first and fourth pics are your cruise control vac servo....cap off the tee fitting for now.
the second & third pic is a vac hose that should go from the plenum fitting in the pics to a fitting on the passenger side valve cover....if you cant get a hose soon, you could cap off the fitting on the plenum for now....other wise you will have a vac leak.
It's probably wise at this point to look EVERYTHING over and start making a list
Senormac
Defender
14
Nov 9, 2014 02:07 PM
NiteTrain
Mar 19, 2013 01:47 PM
sloppyjoe
May 10, 2010 01:38 PM
lipadj46
Nov 16, 2009 02:46 PM
disco12
Feb 19, 2006 03:24 AM
