wont start
Old Aug 2, 2010 | 08:47 PM
bentonrover's Avatar
Default wont start
99 bosch is not starting. No usual clicking associated with battery and starter. Tried jumping battery nothing. Hits starter while cranking nothing. Hit fuel tank while cranking nothing. Tested battery and alt couple of weeks ago and both are in range. Stuck at work. Any in put besides a tow truck is appreciated. Thanks
Old Aug 3, 2010 | 12:29 AM
Well found out it was the starter. Small conncecting wire melted/rotted away. Jump the wires with a scewdriver and got it home. Tried to start again to pull it up further in the drive way and it started a fire. Sparks hit the melted wire and oil lucky I had my garden hose to put it out. What a night. Hopefully all is well when I check it in the morning for a starter changout
Old Aug 3, 2010 | 05:18 AM
wilson96rr's Avatar
If it is just the wire, you could probably just replace the wire. The starters on these vehicles rarely fail due to wearing out from what I have read. Just a thought.
Old Aug 3, 2010 | 09:03 AM
You think. How can I just change out the wire? Looked at the rave cd. Still little lost on how to change out the starter. Round bolts are they kidding me? 6 mm allens..
Old Aug 3, 2010 | 10:16 AM
krazzz's Avatar
Depending on which wire it is, yes you can replace it. If it is the thick red wire that one is very easy to replace.
Old Aug 3, 2010 | 03:27 PM
Its the little wire not the power one. How the hell do you change this thing. Rave tells me nothing. Top bolt is trying to brake my will
Old Aug 3, 2010 | 05:30 PM
wilson96rr's Avatar
The little wire is simply the trigger wire for the starter. It should be pretty easy to repair. You may not even have to remove the starter. Just be sure to disconnect the neg bat terminal first if you are removing the starter or wrenching in that area.
Old Aug 3, 2010 | 08:00 PM
Thanks again guys for the advice. Hopefully I can just change it out. Do the solenoid come off the starter itself?
Old Aug 3, 2010 | 08:47 PM
LRScott's Avatar
Might consider the possibility of a crank shaft positions sensor failure. Its a fairly common problem for bosch rovers and relatively easy to repair. Have you checked to see if you get spark?
Old Aug 3, 2010 | 09:49 PM
hey lrscott where's that? Is that on top of the starter/solenoid? Small wire that connects
