Sponsored by: CARiD
02 disco 2 abs sensor change/other symtoms
Old Mar 22, 2015 | 04:21 PM
norwood16's Avatar
7th Gear
Default 02 disco 2 abs sensor change/other symtoms
hey!, i just ordered all 4 of the abs wheel sensors to install on my disco. im not getting the 3 amigo lights but did have it on a code reader at a shop and they came up bad. have always had a problem of my breaks locking up if i have to jam them. horrible on ice. tried to milk it for some time and now i have horrible break peddle response. I have to mash the breaks all the way to the floor and it creeps to a slow stop. im not loosing any fluid either.
so, im going to replace all 4 abs. any other ideas/recommendations on what could be wrong? can the abs sensors come out without removing the whole wheel hub?
Thanks Forumies!
Old Mar 22, 2015 | 05:45 PM
dusty1's Avatar
worn out rubber brake lines.....old nasty or contaminated fluid.......crusty/damaged calipers.......bad pads.....to name a few. I would at least flush out the fluid
yes you can pop the sensors out in place
Old Mar 22, 2015 | 06:20 PM
norwood16's Avatar
7th Gear
i have new pads on. kind of happened over night? calipers good too
Old Mar 23, 2015 | 06:56 AM
drowssap's Avatar
are you still driving on the 13 year old rubber brake hoses? And have you tried bleeding tbe brakes using the ABS pump?
KlamathMatt
Apr 17, 2020 05:27 AM
LADEROUTE
Mar 12, 2014 08:58 PM
collin Barrows
Aug 28, 2011 07:13 AM
twaszak
Jun 4, 2011 07:49 AM
