Sponsored by: CARiD
02 disco abs wheel sensor/install
Old Apr 5, 2015 | 01:23 PM
norwood16's Avatar
7th Gear
Default 02 disco abs wheel sensor/install
so changed out all 4 wheel sensors today on my disco. a little helpful hint for getting them out of the pesky wheel hub. after rotors and caliper bracket is off, unhook sensor and unhook all clips and pull gaskets. pull wire out from connector inside of engine well first.
pull wheel end towards you. keep feeding wire to you until clip on tube end is almost to wheel hub. take a grinder with a light grit sanding wheel and sand of the hub changes/ribs on connector jacket. They will slide right out!
I did the same thing on the new connectors. buffed off the ridges and hub changes. ity will not eat through the protective jacket and will now fit through hub hole. Saves major time with out taking off axle brackets!
KlamathMatt
Apr 17, 2020 05:27 AM
RANDY04D2
May 29, 2012 10:13 AM
sayeedA
Dec 7, 2011 10:19 AM
twaszak
Jun 4, 2011 07:49 AM
bentonrover
Jul 23, 2010 10:51 PM
